Should I pull the trigger?
#41
Posted 06 September 2008 - 05:01 AM
#42
Posted 06 September 2008 - 05:18 AM
You should begin your research here by reading 968 Golden Rules; Do's and Don'ts
http://www.968forums...?showtopic=1225
Standard Maintenance items you should be aware of;
DME Relay (About $27, you should keep a spare in the glove compartment)
Heater Control Valve
Caster Blocks
Missing Clutch Inspection Port Plug
Passenger Side Power Steering Hose leak
If you don't know the last time belts were done, it is good insurance to have it done. While you're in there, balance shaft seals tend to leak.
Take it for a good long drive, make sure that fans go on and temp gauge stays in the 8:00 O'Clock position.
I'm sure you'll find lots more hints by reading through the threads, don't hesitate to ask questions.
Regards,
Edited by 94SilverCab, 06 September 2008 - 05:19 AM.
#43
Posted 06 September 2008 - 09:48 AM
Travis
#44
Posted 06 September 2008 - 10:07 AM
Johann,
That becker looks like a nice match for the 968. Does the NAV function as good as it looks?
Smokiemon,
The nav works quite well, but you only have small display on the right and you can not see a map. But it is very clear with it's instructions. You also get it with a full color display but that costs a little more.
Regards,
Johann
#45
Posted 06 September 2008 - 10:54 AM
#46
Posted 07 September 2008 - 07:55 AM
Joe
#47
Posted 07 September 2008 - 06:50 PM
Anyone know a place in the SF East Bay to get a Venture clear bra installed? I would like to do that as soon as I pick it up.
Travis
#48
Posted 08 September 2008 - 03:55 AM
#49
Posted 08 September 2008 - 05:33 AM
Clear Armor Protection in San Carlos, CA
#50
Posted 08 September 2008 - 11:50 AM
#51
Posted 13 September 2008 - 07:11 AM
One question I have is on the engine cover. I see a lot of pics of engines that have the cover on the front surrounding the engine. Mine does not. I'm assuming that it had one but is gone. Is it good to have? not have? Is this something I should think about getting or is simply aesthetics?
Travis
#52
Posted 13 September 2008 - 07:20 AM
Congrats !
Posted 18 September 2008 - 08:07 PM
Thanks to all for your advice and opinions. I'll post pics when I get back!
Travis
#54
Posted 19 September 2008 - 04:09 AM
#55
Posted 19 September 2008 - 05:02 AM
#56
Posted 19 September 2008 - 10:54 AM
I am heading to the shop with my '95 968 on Monday. It has 35k miles on it. Here is what I'm looking at getting done for my own piece of mind. Please let me know if there is anything else I should have done since I'm in this far... I did a PPI and there were a couple of minor things like the motor mounts and a possible seepage from the power steering hose. I'm going to take care of that stuff either on my own or at a later time. I'm more concerned with the major stuff that could turn out to be horrible if not done.
Timing belt/Balance shaft belt, tensioner and rollers (kit)
cap & rotor
oil change
Since they are changing out the timing belt, I might have them change the water pump
I also picked up a spare DME (993 style?) & Heater Control Valve to keep around
Anything else I should have them change? I do want to do some work on my own (I'm pretty good with a wrench) but the timing belt, etc. takes too much time for me to finish (small kids)...
I'm getting restless & won't be able to sleep Saturday night!
Travis
#57
Posted 19 September 2008 - 11:02 AM
#58
Posted 19 September 2008 - 11:31 AM
#59
Posted 19 September 2008 - 07:59 PM
#60
Posted 20 September 2008 - 05:10 AM
Regards,
