open Passenger door
1 you need to remove the passenger side dash end plate
2 then the one screw in the long dash strip at the end
3 remove the little oblong filler piece out of the dash, next to the air vent
4 remove the two screws from there
5 remove the round rosette from next to the clock/temp display (use a pair of long nose pliers just the tips in the longest slot and twist)
6 remove the one screw from there
7 remove the four knobs from the heater controls
8 remove the face plate from the heater control
9 remove the four screws from there
10 pull the heater controls forward a bit
11 you should now be able to get the long trim to move and take off
be very careful with the hazzard switch the lugs are very fagile, the rest should be very obvious
replace is the reverse of removal but remember the little hose for the air sensor.
