Maybe 100 hours use.
Includes all manuals, antenna, back lit remote and original shipping box.
$300 including insured shipping
I recently upgraded to a HDMI system. So I am selling my AVR this is a amazing reciever and in excellent condition.
From the Manufacturer
Thanks to the latest surround technology such as Dolby Digital EX, DTS-ES, and our own Logic 7 processing, in addition to a seven-channel, high-current, ultrawide-bandwidth amplifier, the AVR 525 doesn't miss a beat. Make your program selections from a vast array of digital, analog, and wide-bandwidth component video inputs, manage the bass with our Triple Crossover system, and extend the music to a second zone with A-BUS Ready technology or assignable rear-channel amplifiers. Wherever you want your music and movies, however loud you want them, the AVR 525 can handle the job.
Features:
- Audio
- Stereo Mode Continuous Average Power (FTC) Per Channel : 85 Watts per channel at <0.07% THD, 20Hz – 20kHz, both channels driven into 8 Ohms
- Seven-Channel Surround Modes, Power Per Individual Channel: Front L & R Channels-- 70 Watts per channel at <0.07% THD, 20Hz – 20kHz into 8 Ohms; Center Channel-- 70 Watts at <0.07% THD, 20Hz – 20kHz into 8 Ohms; Surround Channels (L & R Side, L & R Back)-- 70 Watts per channel at <0.07% THD, 20Hz – 20kHz into 8 Ohms
- Input Sensitivity/Impedance Linear (High-Level): 200mV/47k Ohms
- Signal-to-Noise Ratio (IHF-A): 95dB
- Surround System Adjacent Channel Separation: Dolby Pro Logic I and II--40dB; Dolby Digital--55dB; DTS--55dB
- Frequency Response at 1W (+0dB,–3dB): 10Hz – 100kHz
- High Instantaneous Current Capability (HCC): ±45 Amps
- Transient Intermodulation Distortion (TIM): Unmeasurable
- Slew Rat : 40V/µsec
- FM Tuner
- Frequency Range: 87.5 – 108.0MHz
- Usable Sensitivity: IHF 1.3µV/13.2dBf
- Signal-to-Noise Ratio: Mono/Stereo 70dB/68dB
- Distortion: Mono/Stereo 0.2%/0.3%
- Stereo Separation: 40dB @ 1kHz
- Selectivity: ±400kHz 70dB
- Image Rejection: 80dB
- IF Rejection: 90dB
- AM Tuner
- Frequency Range: 520 – 1710kHz
- Signal-to-Noise Ratio: 45dB
- Usable Sensitivity: Loop 500µV
- Distortion: 1kHz, 50% Mod. 0.8%
- Selectivity: ±10kHz, 30dB
- Video
- Television Format: NTSC
- Input Level/Impedance: 1Vp-p/75 Ohms
- Output Level/Impedance: 1Vp-p/75 Ohms
- Video Frequency Response
- Composite and S-Video: 10Hz – 8MHz(–3dB)
- Component Video: 10Hz – 50MHz(–3dB)
- General
- Power Requirement: 120V AC/60Hz
- Power Consumption: 120W @ idle, 1,040W @ rated output (7 channels driven)
- Width: 17.3" (440mm) x Height : 6.5" (165mm) x Depth : 17.1" (435mm)
Product Description
Thanks to the latest surround technology such as Dolby Digital EX, DTS-ES and harman/kardon's own Logic 7 processing, in addition to a seven-channel, high-current, ultra wide-bandwidth amplifier, the AVR 525 doesn't miss a beat. Make your program selections from a vast array of digital, analog and wide-bandwidth component video inputs, manage the bass with harman/kardon's Triple Crossover system, and extend the music to a second zone with A-BUS Ready technology or assignable rear-channel amplifiers. Wherever you want your music and movies, however loud you want them, the AVR 525 can handle the job.
