18" wheels
Posted 02 September 2005 - 10:42 AM
Posted 02 September 2005 - 07:12 PM
Posted 02 September 2005 - 09:56 PM
Posted 03 September 2005 - 09:04 AM
Sport Classic IIs have 65 offset rears and work fine. A thin 5-10mm spacer will give them a perfect stance.
Hmm, I just happen to have a set of 7mm spacers that I'm removing from the 924S track car
Posted 04 September 2005 - 05:53 AM
eric - you know i hate spacers - it's a race thing - they aren't legal in racing because they aren't considered safe - i've never used them for that reason - i've also had balance issues on other guy's cars because of them
if you love the wheels though, and you use good spacers, you could probably get away with it fine - a lot of guys do on the street, and they seem to be doing just fine
this was an odd porsche phenomenon i discovered when i started talking to porsche guys - in 25 years of builidng cars i had never run into any other make of car that successfully used spacers or even considered it - very weird that is so accepted a practice on this one
Posted 04 September 2005 - 06:25 AM
Posted 04 September 2005 - 08:53 AM
I avoid them due to classing considerations. But if sitting on the lugs is good enough for my rotors and wheels it should be good enough for spacers.
Posted 04 September 2005 - 08:58 AM
Posted 04 September 2005 - 06:40 PM
bruce - to answer your question, most people don't use longer lugs with narrow spacers - this is bad - the stock lug nuts are already bad enough (and also not legal for racing) - less threads available on them because of spacers is asking for a failure - that's a problem
any off center alignment of the spacer is a balance issue - you should also have them balanced with the wheel - this is not easy
they aren't legal for racing - that's a problem
like i said though, plenty of guys use them on the street and have no issues - i just would not trust them under heavy load or on the track
Posted 05 September 2005 - 01:57 PM
dave - i thought you had inside rubbing without the spacers?
With the rear suspension at full drop on the adjuster, on a hard corner, or full compression, the Continentals I had just barely touched the inside of the wheel house. Those 265mm Continentals were WIDE. Physically wider than the 275 Yoko's I have now, which are not a problem.
Posted 10 September 2005 - 09:14 AM
Small 5mm spacers are fine and pose no problems. Thicker and I would go with bolt on spacers such as H&R. I used them on the rear of the GS while sending over 390 hp to the rear wheels. So in terms of safety, there is no issue if used properly. The key word being properly. Keep in mind that many tire shops such as American Tire (I don't care for them anyhow) will not work on your car if it has spacers-including factory ones. Another downside with spacers is the hubcentric nature of the wheel is lost if thicker spacers are used unless the spacers are hubcentric like H&R spacers. Racing regulations vary from track to track so I cannot comment there.
I was looking at those wheels as well and they are just 4 miles away. They are a bit heavier than some, lighter than others, but claim to be forged. I may go over to check fitment.
Lee
Posted 10 September 2005 - 02:42 PM
Lee
4 miles. get in that car and check them out
Posted 17 September 2005 - 08:03 AM
Posted 17 September 2005 - 08:19 AM
Posted 17 September 2005 - 04:26 PM
I like the Fikse Mach V and their new Profil 13 models. According To Fikse, their Profil 13's are 20 lbs for 9.5" X 18" and 21 lbs for 11" X 18"...the Mach V model is 1 lbs heavier per wheel.
Jason
Posted 18 September 2005 - 10:52 PM
In the process i came across a Porsche bulletin, where they strongly recommend not to use 18" wheels on models not originally equipped with such wheels.
Check the bulletin: http://www.update.uu.se/~bqt/18in.pdf
best regards
Ragnar
Posted 19 September 2005 - 06:54 AM
basic physics here - more mass equals more stress - more tire contact area means more stress
gotta be careful on choices - i don't know where the limit is on our cars, but i do know that guys on the track snap spindles all the time, so i have to think it's not too far away from stock
if you want to go big, you really have to go lighter than stock to compensate for the increased size and still stay in the ballpark - unfortunately, most guys don't do that, often for budgetary reasons, and ultimately roll the dice, break something, and end up spending more money than if they would have bought the right wheels in the first place
i figure we'll start seeing some worn out stuff pretty soon - a lot of guys have gone to 18s lately, and not many of them have gone light
Did you end up getting them? I really want to see these wheels on a 968!
Not yet, I was hoping that Lee would drive over and check out the quality of the wheels. I like the look based on the p-shop image.
Posted 19 September 2005 - 07:05 AM
Posted 19 September 2005 - 07:24 AM
I seem to recall reading someplace that there was a version of the 968 that came with 18" wheels. Anybody know?
I emailed these guys way back then and still have not received a response. I will try again today. If not, I may possible be able to drive past them on the way up to getting the car smogged.
Lee
