Threads: 104
0
I know I had this problem years ago and i recall it was a simple fix but i can't remember what the fix was. My trunk lid can no longer be opened by the key but it can be opened by the release button next to the pedals. Is it just a fuse? Thanks!!!
92 968 cab, 1 of 1 Mint green cab, full leather black intr, PCNA promo car, 9th cab for NA market, 6 spd, 968 coupe and cab registry keeper. PCA 968 register advocate.
Threads: 224
0
I havent used the key to open the trunk since I got the car. W/ that kind of neglect, chances are mine wont work either
I love my 968 for what it is & don't hate it for what it isn't!
Threads: 104
0
Threads: 20
0
Ironically, my trunk lock release stopped working just yesterday. Drat! And all the makings for a party at a friend's house were in my trunk (ie, rum, beer, wine, and food). No pressure, but I had thirty people standing around, waiting impatiently for me to open the trunk. Thanks to everyone's previous postings, I knew how to get to the manual cable at the driver's door. Party saved!
But it's embarrassing to have to pull that cable to get in the trunk, so I'd like to get this working again. Putting the key in the lock does nothing, and the inside release does nothing either. I changed the fuse, but it still didn't work.
I followed rustech's suggestions, but wasn't able to see a button on a brown microswitch next to the key assembly. I saw the wire going into what must be a switch, and a small metal bar that is pushed by the keylock which in turn pushed a tiny red button. I pushed on the metal bar with my finger, which pressed the red button, but nothing happened.
I wasn't sure what rustech's next advice was about closing the trunk lock assembly with my finger...clarification?
Any other advice?
Thanks!
Kathy
Kathy
happysails2you
Kathy - Annapolis, Maryland, USA
1992 968 Cabriolet - "Baby"
Horizon Blue, Linen/Classic Grey
Porsche is a two syllable word.
Threads: 20
0
Thanks for the suggestions, guys. The interior trunk release button does not work, with the key in ignition and switched to 'On'. I'm going to check to see if there are any loose wires, double check the fuse again. And I don't have any other electrical problems. (knock on wood) I'm thinking it's either a loose wire or the microswitch has gone to microswitch heaven. Will take a look at this more one night this week and let you know what I find.
Kathy
happysails2you
Threads: 20
0
So I'll show my lack of knowledge -- what's an actuator?
happysails2you
Threads: 6
0
Thought I'd add my experience here for the benefit of anyone else having a similar problem (and reopen a 4 year old thread!)
Symptom: Trunk release on our '93 cab doesn't work usung the external key lock, but works fine using the internal remote release button near the pedals.
Fix: After checking and cleaning (contact cleaner - can't believe how much that stuff costs!) the connectors on the microswitch lead inside the trunk near the lock (behind the carpet) and tightening the earth connector nearby, I found the microswitch was actually working but the plastic cam on the lock tumbbler wasn't activating it. Seems the metal strip on the microswitch has relaxed over time and simply bending it up slightly so that the cam contacted it sooner and activated the microswitch has solved the problem. Cheap and easy!
Cheers
Jono
UK-spec '93 Cab, Cobalt Blue, light grey leather interior & sport seats.
Threads: 4
0
I have been wondering how to solve this problem for a while. The duct tape solution is simple and works well. Thanks,
Jim...
92 Polar Silver Cab
79 911 SC Targa
