Help with purchase decision..
#21
Posted 31 March 2012 - 05:18 AM
I found a receipt in the glove box from last year (october 2011) showing that the timing belt was changed and the water pump was rebuilt (on the same receipt was a note stating the radiator was in bad shape and was fixed temporarily). I'm going to re-do the timing belt, balance shaft belt and all the rollers, but am on the fence about doing the water pump.
A more thorough inspection has revealed a history of kludges. I have non-original relays creatively wired into the fuse-box. The cooling tank expansion cap is non-original and not correct and allows water (not coolant, they only had plain water in it *sigh*) to escape -- thus probably the cause of the overheating.
The wire from the coil to the distributor is bodged together -- electrician's tape and the wire coiled and stuck in the receptacles.
And I'm sure I'll find some more "creative" mechanical work as I get further into it... I suspect my post count here will start going up dramatically!
Oh.. and my favorite so far... there's a spot on the left flank where someone has scraped off a Herbalife sticker -- thus leaving Herbalife scratched in the paint. Herbalife vendors should not be allowed to own Porsches.
#22
Posted 31 March 2012 - 07:45 AM
#23
Posted 31 March 2012 - 09:12 PM
Best of luck. -Scott
#24
Posted 01 April 2012 - 06:13 AM
#25
Posted 01 April 2012 - 10:52 AM
#26
Posted 01 April 2012 - 04:15 PM
#27
Posted 01 April 2012 - 04:27 PM
#28
Posted 01 April 2012 - 06:30 PM
#29
Posted 02 April 2012 - 06:15 AM
I see that Pelican offers the Laso brand for the water pump. However for my purposes, I'd prefer to use Paragon (they'll ship via US Express Mail, which is cheaper and less hastle from Chilean customs), but they don't list a brand for the part. Anyone know what brand they use?
The relay that's been creatively wired is the one for the aux cooling fan. Running through the Clark's garage testing procedure reveals that it isn't working correctly (surprise, surprise). Paragon doesn't have it in stock, and Pelican doesn't have the $120 version in stock either (they offer an alternative for $220). Where might I be able to find this cheaper?
Edited by mbardeen, 02 April 2012 - 06:21 AM.
#30
Posted 02 April 2012 - 06:59 AM
http://www.type911sh...ge/1?shop_param=
http://www.partsforporsche.co.uk/
All in the UK , have look and see what shipping costs .
Use the laso pumps , and did about 10 of them on different cars type 944/968 , never had a problem , but always change the pump with the belts .
I thgink laso is the only one who makes these pumps , and is if i undestood correct a porsche supplier or used to be .
good luck with the restoration
Edited by vliegwielolaf1234, 02 April 2012 - 06:59 AM.
#31
Posted 02 April 2012 - 07:35 AM
No luck at any of the UK suppliers, but did find a relay with matching description at:
http://www.allzim.co...e615_2e104_2e04
They list the part number as 944.615.104.04, where as the porsche parts catalog lists it as 944.615.104.03. I wonder if there's any difference between them...
#32
Posted 02 April 2012 - 09:15 AM
#33
Posted 02 April 2012 - 09:51 AM
They had new OEM replacements for a very reasonable price. Your symptoms sound like mine, my plastic impeller had spun on the shaft.
#34
Posted 04 April 2012 - 06:38 AM
I think I need to start a thread elsewhere, since I'm no longer purchasing the car. In other car-related forums there's a place for "build" threads, kind of a general holding place for one person's car. Is there an appropriate place here for such a thread? Maybe a blog?
#35
Posted 04 April 2012 - 07:11 AM
the garage area. that is the perfect place for a "build"
#36
Posted 05 April 2012 - 07:50 AM
My car is going to need a lengthy restauration process, so I wanted a place where I could jot down notes, place before&after photos, complain about the cost of valve cover bolts, etc, without bothering people that aren't really interested in the process. I think the blog area is the most appropriate for that, supplemented with the Garage areas for the photos.
#37
Posted 05 April 2012 - 08:45 AM
here it is:
http://www.968forums...__fromsearch__1
#38
Posted 05 April 2012 - 08:52 AM
#39
Posted 13 April 2012 - 04:44 PM
http://www.968forums...-968-ownership/
#40
Posted 13 April 2012 - 06:06 PM
